2000 Poloris 335 sportsman rear diff Fill plug?
Old 07-10-2018, 03:17 PM
Projects's Avatar
Default 2000 Poloris 335 sportsman rear diff Fill plug?
Hi, This may seem impossible but, its not. I have drained all fluids in my 2000 polaris 335 sportsman. I found front diff fill plug, trans fill (it has has a dip stick)
But I can not find rear diff fill plug. I checked almost every post on line,every u-tube video. All say SHOULD be here or there. NOPE! I called polaris.com. NOPE the person who answered the phone was polite but could not tell me. I went to polaris dealer. NOPE. They checked there computers for 5+ minutes.
Does anyone have a 1999 tru 2000 335 sportsman? Do you have a picture of rear diff fill plug?
I do not believe the 500 sportsman is the same.
Thanks for the help.
Old 07-10-2018, 07:53 PM
850 trailrider's Avatar
I may be wrong But could it only have one fill plug if trans and rear diff is one assembly?[takes only one type fluid ]
My ATP has separate gearcase and rear diff mine takes 2 different fluids
hopefully someone has better answer
Old 07-11-2018, 07:09 AM
Projects's Avatar
Default Rear Diff Filler Plug?
Thanks for the response. It almost seems like it could be (1) gear case connected. The dip stick is off the transmission and it is lower in the case?
When I ordered the service kit, It came with separate fluids for transmission and rear Diff. It is almost comical, (unless you are me) that I do not have an answer
for this question from Polaris.
Thanks again.
Old 07-11-2018, 09:35 AM
Do you have owners manual for it ? If so surprised info not supplied in there. Surprised no one has checked in with better answer than me Good luck !
Old 07-11-2018, 10:17 AM
Projects's Avatar
Default 2000 Polaris 335 Sportsman rear diff fill plug
Yes Sir, I do have owners manual. It is a Universal Owners Safety and Maintenance Manual. It covers multiple engine sizes and Models.
There is a small picture in this Manual. You can not make out anything it is trying to show. You can't tell if it Rt or Lft. and no real picture. More like a stick diagram.
Arrow points at the whole picture.
Factory is supposed to send me a picture? Girl said she could not confirm it is correct but, she would send.
Old 07-11-2018, 01:37 PM
polman500's Avatar
The gearcase is all one unit. Number 32 is the drain. Number 13 (dipstick) is the fill hole. Your machine's main gearcase holds 32 oz. of AGL transmission fluid.
Old 07-11-2018, 05:09 PM
Projects's Avatar
Hey Poleman, That looks like my gear case. We had wondered if it was 1 unit but was led astray as they sell 2-different gear oils, 1 for the transmission and 1- for the rear diff in the kit.
Thank you for the response. If possible, where is this diagram from? What is #33 & #34, it also looks like a drain?
Old 07-11-2018, 05:29 PM
polman500's Avatar
It's the Polaris Parts Catalog. Here's a link.
LOL...you are correct on the drain. I typed in the wrong number. 33 is the drain plug. 34 is the sealing washer.
http://parts.polarisind.com/Browse/Browse.asp
Old 07-11-2018, 09:27 PM
Projects's Avatar
Thanks again. Sorry so late but after I got your diagram I went right out to the quad. Everything makes sense. Quad is back together.
Thanks.
Old 07-11-2018, 09:47 PM
polman500's Avatar
Glad to help.
Quick Reply: 2000 Poloris 335 sportsman rear diff Fill plug?
