2005 polaris 400 sportsman 4X4 no juice getting to key switch
no juice getting to dash or key switch & doesn't seem to have spark or juice to key switch or dash when I cross starter solenoid but does turn over then but then I have juice to headlight switch on handlebar but have to play with headlight switch to make lights come on! any replies would be greatly appreciated?
so when you turn the key there is no power to anything? make sure the kill switch is working correctly, make sure the actual switch plug is in and not corroded. there is a circuit breaker in a black pouch somewhere along the route from the battery you can check as well.
new info when I checked with tester there is juice coming into key switch from 2 orange wires with key off & with key on juice going out of switch on 2 red & black wires & yes winch & lights do work
nothing happens when I turn key to start possition
did you check to see if you have power on the small red wire connected to the solenoid when you have the key turned to the start position? there should be.
