proper fluid for the front differential
On a 1999 Polaris Sportsman 500, what is the correct fluid for the front transmission?
If you're talking about the front gearcase/differential, your 99 uses regular gear oil. Polaris calls it Angle Drive but any good 75w-90 or 80w-90 will work.
Perfect, thank you. Another question might be. On the rear disk break? There looks like two grease zerts? |
No, those are bleeder screws to bleed air out of the brake system.
Perfect, thank you again. |
Originally Posted by KrisHart
(Post 3403008)
Perfect, thank you. Another question might be. On the rear disk break? There looks like two grease zerts? https://cimg2.ibsrv.net/gimg/atvconn...5812366bee.jpg https://cimg3.ibsrv.net/gimg/atvconn...0df8100362.jpg |
