I have a 2000 Polaris scrambler overheating problem.
I have check the following:
- Fan Temperature switch, Good
- Thermostat, Good
- Water Pump, Good
I noticed that when the radiator cap is off I can see radiator fluid squirting a crossed the opening. There is a blind between the inlet and outlet side of the radiator. It forces the fluid to travel through the radiator to be cooled. It looks like it maybe crack so fluid is squirting through the blind. Is this normal or do I have a cracked radiator?
- Thermostat, Good
- Water Pump, Good
fngboy
07-26-2019 08:33 PM
Chris Mange
08-13-2018 12:25 AM
Raider7878
08-02-2018 02:33 PM
