Shooting Oil From 2001 Xplorer 250
Hey Guys,
I just inherited a 2001 Polaris Xplorer 250 from my uncle. I started going through everything, cleaning the carb, replacing fuel lines, fuel filters etc due to it sitting for 2 years. I got it started and noticed oil coming from this black tube that has cables within in it. I believe this is the wire harness leading from the engine. Please see video below. Any help would be greatly appreciated.
ok I re looked at the video closer and I see the wire harness now sorry didn't pay attention the first time. if that harness is coming from the stator(crank case) then it might be the main crank seal but if it is the engine is not going to last long with the air leak. pull off the cover and you'll be able to tell quick enough.
