1996 Polaris 500
Old 01-16-2019, 12:17 PM
Todd Land's Avatar
Default 1996 Polaris 500
I am trying to fix my the speedometer on my 1996 Sportsman 500. I put a new cable on and checked the actual speedometer, it works with a drill supplying the turns. I have taken off the angle drive for the cable. It seems the key drive is broken. I cant find a part to fix it. can anyone help out?? Thanks Todd
Old 01-16-2019, 12:24 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
where does the angle drive bolt into the transmission area or somewhere else so I can try to find a part number for you. been too long since ive seen one
Old 01-16-2019, 12:30 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
never mind I found it and here are part numbers and hope this what you need.
3280219 ADAPTER,DRIVE
3280217 KEY,SPEEDO.DRIVE
3280164SEAL,ANGLE DRIVE1
5020741BUSHING,SPEEDO.DRIVE
Old 01-16-2019, 12:49 PM
Todd Land's Avatar
Thank you that is the key drive part 3280217. Unfortunatly the key drive is discontuniued. Any thoughts?
Old 01-16-2019, 02:13 PM
94harley's Avatar
Do you have the old damaged speedo cable still? Cut off the "squared" end and make a key to drive the speedo.
Found a pic of what they used to look like.
Pic robbed from the net.
Old 01-16-2019, 03:56 PM
Todd Land's Avatar
Thank,s you are a genius. Lots of help!!!
Old 01-16-2019, 04:06 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
we used to so that years ago to save money on the snowmobiles and it worked fairly well.
Old 01-16-2019, 04:18 PM
Big Frank's Avatar
THE BERMINATOR
If all else fails find a key the same length for something else.
frankehvac
08-10-2012 06:29 PM
timindy
07-06-2011 12:57 PM
pwoens
06-20-2008 04:36 PM
Adictif
01-15-2006 05:15 AM
tuffguy31
05-27-2004 11:05 AM
Quick Reply: 1996 Polaris 500
