600 sportsman axel yoke
Believe the rear plunging joint is replaceable seen it on partzilla not sure about front? don't know which front or rear is what you need ?
I would replace the whole axle [MAYBE CHEAPER] if it was me EBAY? If axle splines are worn out chances other parts are to on axle. Might not be worth playing around with but just my 2 cents
Thanks for the reply.
Its the front yokes that I need . I broke a new front axle on the weekend. The 4 wheel drive engaged on its own while spinning on ice in 2 wheel drive. The axel broke off clean at the diff. I had to weld a bolt on the end to get it out.The other axel seems fine except for the spines on the diff side. Any suggestions on a reasonably price after market axel?
Im assuming its an 03 or 04 since it looks like the 05 went to cv front axles and the 03,04 are yoke and cv front axle. Depending on the build date and year(03 has 2 axle choices) I have one of each OEM polaris axles Id make you a deal on if you're interested(Brand new, never installed) If you're interested let me know in a pm and we'll see what we can do.
The numbers I have are 1380199 "If built before 10-3-02"
1380218 "If built after 10-3-02"
Ebay sells aftermarkets for pretty cheap. Cheaper than I would sell these for, but these are OEM. Depends on what you want to put on your machine. I dont have anything against aftermarket(use them all the time) but I dont buy the "really" cheap ones so I have no response on how well they those are built. OEM is usually still pretty safe.
