2001 polaris trail boss won't start I've put in a new carb all new fuel lines$$stilln
Old 03-04-2019, 06:13 AM
scootergptx's Avatar
Supersock
Hired Gun!
Unscrew the carb drain screw, just to make sure you're getting gas in the carb.
I had the same quad, and this was never and issue. Even switched the carb from a 330 Trail Boss and it fired up. Jetting was another issue, but it did start.
Have you looked inside the new carb to make sure it's got all the right jets in it?
Old 03-04-2019, 09:12 AM
Jaushawa's Avatar
Gas comes out the drain hose I'm going to take carb back off today and check the parts in side it it came ready to install and ride they said
Old 03-04-2019, 09:38 AM
Supersock
Hired Gun!
Mine as well as a lot of others were very cold natured quads, even in the summer. So when it does start, don't be surprised if it needs to warm up just a bit.
Not sure that it would keep it from starting, but you may want to check out the choke plunger assembly if you haven't already.
Old 03-04-2019, 07:29 PM
Jaushawa's Avatar
I put all new chock assembly on wen I put in New carb I took carb off and checked air fuel screw on bottom of carb and it was out way to fare so I put it at 2and a half turns out going to get it back together and hope it starts ill let u no
  #15
Old 03-05-2019, 06:47 AM
Jaushawa's Avatar
Any more ideas
  #16
Old 03-05-2019, 06:54 AM
Supersock
Hired Gun!
No pin holes in the diaphragm?
  #17
Old 03-05-2019, 08:51 AM
Jaushawa's Avatar
Pin hole ??
  #18
Old 03-05-2019, 08:52 AM
Jaushawa's Avatar
The carb one is brand new
  #19
Old 03-05-2019, 09:20 AM
Supersock
Hired Gun!
It's not used, but I'd bet it's been sitting on a shelf for a long time. Depending on how it was stored, it could have weakened any rubber in it. Just another possibility.
If you've got a good spark, you're getting air and fuel into the carb and it's not starting, I would say it would be something inside the carb.
A very small hole in the diaphragm, or maybe a small crack would cause it to not work properly. Not running smoothly or not starting is one sign.
  #20
Old 03-05-2019, 09:36 AM
Supersock
Hired Gun!
Have you checked the compression or the valve clearance?
Quick Reply: 2001 polaris trail boss won't start I've put in a new carb all new fuel lines$$stilln
