2009, 850 sportsman, throttle problems
I imagine this has been on here a few times before, but how to find? Anyway I had a lot of trouble getting the throttle cable adjusted and finally insulated the points in the throttle box. That helped the cutting out problem. However now the RPM is erratic and when idling the RPM might go from 1200 to 1700+ all by itself. I did once get a stuck throttle code before I put a piece of plastic between the points. Any help would be really appreciated.
