Need a clutch kit or other idea 13 500 w/ebs
So i was doing some spring maintenance on my 13 500 ho/ebs and found my helix is gouged pretty good as well as the rollers. The primary clutch weight pins are worn as well as the holes in the weights. I figured no big deal i will order up some replacement parts and be good to go. I didn't realize the helix alone is $350??? So I start looking for a kit figuring i could likely save a couple hundred bucks and maybe upgrade a bit and get all the parts in one shot, but i cant find one with a helix for a 13 500 w/ebs. Has anyone seen one? Or know of an aftermarket helix that doesn't cost quite as much? With weights and springs id be at $700!
The first place I would check is EPI. The second would be Dalton. Niche also makes some copies of Polaris clutches but I don't know what they do and don't have. Those are the first 3 that come to mind but there are several others. AAEN has a lot of Polaris stuff. Rick Ritter at RCR seems to know everything about Polaris but I think his specialty is getting more performance out of 400 2-stroke engines.
https://epiperformance.com/polaris-16/
