wheels stoped turning at full throttle! HELP
I got a clutch question… I just got 27” Dirt Devils, tonight I went a very steep hill, in high gear 2 wheel drive, and the wheels stopped turning at full trouble. In 4x4 in low, the tires will dig holes. So what’s up? What do I need to do? A clutch kit? A new belt? A new spring? If I have to get something, I would like as much low end as I can get, but I also like a low throttle engagement. Thanks for your help.
<< got a clutch question… I just got 27” Dirt Devils, tonight I went a very steep hill, in high gear 2 wheel drive, >>
Sorta sounds like your clutch did not backshift into a lower range.
Could be bad buttons in the driven clutch. It sounds like the clutch is due for an inspection: drive/driven
Good luck,
