Stupid question about the 500 scrambler plug
I don't think, but I know....
The sparkplug is a pain to get to. It's the same basic motor as the Sportsman, which has pull-off sidecovers, so getting to the plug is easy. When they dropped it into the Scrambler chassis, it's tough to get to.
First, pull the seat & hood off. Then the front fenders. Then the gas tank. Then you see the plug wire with a red water-proof cap. Pull it off. Use the special tool included with the quad in the tool kit to get down to the spark plug. What a pain.
There are two basic ways to get to it....
One is how Quad_man said... and is the right wy to do it...
There is another way though.... from the right side of the machine, you can "snake" your hand and some 3/8" drive tools up in there and change the sparkplug... I have found that to make it painless as possible, you need two sparkplug sockets.. one with the rubber insulator one without, a 1" extension and a 3" extension, and a 3/8 drive ratchet... If you are proficient with hand tools, you can do it in about five minutes.... Otherwise, pull the tank...
I would recommend replacing whatever plug thats in there now with an NGK.. they last a long time...
Another thing... make sure you wash down the engine and underside of the plastic as best you can first.. that way you dont end up with a lot of dirt down in the sparkplug hole...
Good Luck....
Good Luck....
Chocobamofo
07-10-2015 07:46 PM
