No 4X4 on "99" Xplorer 300
Old Jan 9, 2002 | 11:55 PM
jammiller's Avatar
I went to switch into AWD today, and it would not go in. If I put the machine in reverse and push the over ride switch, it works. Looking at the wireing diagram, it looks like there is a switch at the shifter. The switch seems to be an internal switch. Can this switch be adjusted? Is there a trick to adjusting this switch? Any info would help. Thanks, Jack.
Old May 17, 2002 | 02:37 PM
CaptainCody's Avatar
Did you get the AWD working? If so, what was the problem?
Old Aug 5, 2002 | 02:42 PM
Buckmaster128's Avatar
I have a Xplorer 4oo and it is doin the same thing. If u have any advice please give it and in the mean while if u find your problem please post it.
Old Aug 5, 2002 | 10:00 PM
ZoomZoom's Avatar
I would check your switch, which means taking it apart & cleaning & reshaping the brass/copper contacts back to their original shape or buying a new switch. Apperently on early models, the switch was a problem, (plastic ones). I just cleaned mine but beware there are small parts in the switch.
Old Aug 5, 2002 | 10:26 PM
Farmr123's Avatar
Jack, some machines had a switch in the shifter box, some have them on the tranny itself. I don't know the year they switched. If yours is in the shifter box, you can (if you are very careful) clean the contacts. I believe the ones on the tranny are sealed units that you replace rather than clean.
Farmr
MeadowlarkFarm
Nov 27, 2019 08:40 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
rockinkgin
Sep 25, 2015 01:52 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
Jason Richards
Sep 4, 2015 06:17 PM
