sp500 wont go into gear, neutral , reverse lights dont come on either
my sp500 wont shift into gear , wont shift into other gears, but it does drive forward(not sure if it is high or low) the lights on the pod dont work either(nuetral or reverse)??? what could cause this what could this be???
thanks
thanks
mtpockets
There are two chains in the rear case on the sportsman's.....I believe greg sims broke his awile back also. [img]i/expressions/face-icon-small-confused.gif[/img]
ok sorry for that delay, i broke the forward chain, which is the big chain. there is also a reverse chain(smaller). but yea i have the tranny out now and cant seem to get the forks into the case right?? i will put the case on and then i wont be able to shift it(using a pair of pliers). please help me out if you can
thanks
thanks
KimSJoh
14
Jul 18, 2015 07:20 PM
