PREDATOR MOD'S
LOOKING TO PUT ON THE WB SILENCER ON NEW PREDATOR. DO I NEED TO CHANGE JETS AND TO WHAT SIZE (ELEVATION 3500FT). PLUS LOOKING FOR 13 TOOTH SPROCKET, AND SHOULD I GET THE K&N REPLACEMENT FILTER OR THE k&N CONE FILTER (AND TAKE OFF THE AIR CLEANER BOX)? CAN ANYONE TELL ME WHY THE SMALL HOSE ON THE BOTTON OF THE CARB (GAS FLOAT BOWL) DRIPS QUITE ALOT OF FUEL ONTO THE GROUND WHILE RIDING AND WHEN IDLING? THANKS FOR ANY INFO
PREDATOR MOD'S
You can get a 13 tooth front sprocket from SprocketSpecialists.com, order a Honda XR650L late model 13 tooth.
It fits perfectly, I have one on mine. |
PREDATOR MOD'S
thanks for information on the sprocket. did you have to change chains, or is their enough adjustment? how much top end did you loose. Polaris offers diff size rear sprockets, can changing the rear make enough diff. want more low end power. thanks
| All times are GMT -5. The time now is 01:43 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
