2000 TRAILBOSS 325 HESITATION WHEN IT'S HOT
My battery is weak, would this cause my problem? Sometimes you have to crank it with the pull start.
The battery being weak wont matter. Sounds like you need to adjust the air screw when it is hot or maybe it needs to be re-jetted. Most likely it is your airscrew. Turn it 1/2 turn counter clockwise at a time when it is hot and see how it runs. The airscrew should be at least 1 to 1 1/2 turns out. If it is not out enough then it will hesitate.
Is there an easier way to get to the air screw, I can't get to it without removing the carb.Text
Your saying that it's hard to crank the engine over when it's hot? Yes your battery would be weak if that was your problem. Polaris starters are junk and wear out, you might need new brushes in the starter.
| All times are GMT -5. The time now is 10:06 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
