tm or tmx mikuni
Old Feb 4, 2003 | 07:07 AM
vig's Avatar
vig
Default tm or tmx mikuni
I see alot of used carbs on ebay, what is the difference between a tm and tmx?
Old Feb 4, 2003 | 09:33 PM
NCScrambler's Avatar
A Tm carb Is an older version of the flatslide. The TMX Is suppose to be simpler and more effective than the TM. It has fewer parts and Is easier to work on than the TM. The TMX is shorter and thinner than the TM which is suppose to give It better throttle response and more top end power than the TM. The TMX can be hard to tune sometimes and I know alot of people In this forum run PWK carbs. Anyway those are the main differences in the two (there are more differences but they combine to get what I stated above) and I hope this helps you.
Shooterj2003
Jun 21, 2015 07:51 PM
hs6160
Jun 9, 2015 08:19 PM
jayking232003
Jun 9, 2015 02:54 PM
oz_400ex
Oct 8, 2000 02:56 PM
