Raptor 700 pipe question
Old 02-25-2008, 10:16 PM
number1_kid's Avatar
Default Raptor 700 pipe question
Putting a slip on LEXX pipe on my 07 SE Raptor
will the fuel injection be good to handle just a slip on?
thanks
Old 02-25-2008, 11:12 PM
lerea3's Avatar
For the most part the computer on the Raptor will only adjust for altitude and air density. Any time you add something to the raptor you should add a programer. you can try the slip on, then keep an eye on your spark plug. If it turns white or your bike starts popping on deceleration then this means your running lean.
Old 02-25-2008, 11:25 PM
ok anybody on here with a 700 with just a slip on?
pipe is in the mail and the computer well its more money then the pipe
dont plan on putting mods for performance just looks and want the pipe for sound
Old 02-26-2008, 01:49 AM
EdKatt's Avatar
All you can do is try. Just keep a good eye on that plug.
Old 02-26-2008, 01:59 AM
FordNut5's Avatar
You should be fine, efi componsates for air and fuel. If you went with more than just a slip on the programmer would be a necesity.
Old 02-26-2008, 08:43 AM
we will have to see
pipe is in the mail
thanks
Old 02-26-2008, 08:28 PM
lerea3's Avatar
The computer does NOT compensate for air fuel!!!! there is no o2 sensor on these bikes.
Old 02-26-2008, 08:41 PM
dewey_700r's Avatar
What up, i just bought an 08 700r and just put an hmf slip on pipe on it and havent had a problem if u want ill send u a pic of it or whatever. You dont need the programmer or need to change anything unless you are gettin the full system.
ok well what does the EFI on the raptor do?
make it run and thats it?
Old 02-26-2008, 09:03 PM
dewey_700r's Avatar
Dont worry about the EFI the slip on doesnt affect it.
Quick Reply: Raptor 700 pipe question
