Hightower, OMR and other DS650 How To's?
Over the years I have gotten all the how to's off the web I could find.
If you know of others, please let me know and I will add them.
If you created one of these please let me know so you can get credit. If you do not want it posted me me know that also and I will pull the link.
In no real order:
2004 DS650 Owners Manual
Mikuni Carb Theory
Mikuni TM Carb Manual Factory Manual
General DS650 TM Carb Setup Hightower with Altitude and Jet Chat Added
Basic DS650 Suspension Setup Hightower
DS650 Shift Fork Replacement Let me know who to credit.
DS650 Headlight Mod Let me know who to credit.
DS650 Valve Adjustment Let me know who to credit.
Oldmanracing Stock Carb MODS OMR
Gearing Calculator
Race Gas Ratios for octane and $$ (includes Power Mist Nitro plus ratios) TheStir
Shock Sag Calculator
Supertrapp Disk Area and other info
In no real order:
Mikuni Carb Theory
Gearing Calculator
Erin (04-03-2024)
Done and linked.
You ARE the man Scott. Please add the gearing calculator as alot of folks ask for that from time to time. And it answers their tire size questions at the same time. How about OMR's stock carb mod instructions?
There's a few others, I'll research and then PM you. Good info so far.
Awesome job compiling that list. Sad that allot of the information seems to disappear. I think this would be a good time to post this link. The BMW F650 Technical FAQs
I think it's the same site that has all kinds of Faqs on the Rotax motor used in the DS. I recall using them quite a bit back in the early days when no one seemed to know what a DS even was.
It was interesting years ago to find a Faq for leaking water pump seals. That problem had been around a long time. Is it cured now?
that brings to mind another mod I used to advocate and post pics of - tapping threading and intalling a tiny 4mm hose barb in the wheep hole under the water pump and putting a few inches of poly tubing zip tied in a loop to keep debris out of the gap between the water and oil seals. the one time I lost my water pump seals and shaft, it was due to a load of grit that got up in there, bike was about a year and half old, 8 years since and still running the same parts i put in that one time. gncc style riding through creeks ya know.
Administrator¿
Resident Killer!
"A little nonsense now and then, is relished by the wisest men". Willy Wonka: 1971
Cigars! Earth ne'eer did breed such a jovial weed.
A Tiger Doesn't Lose Sleep Over Opinions of Sheep
Resident Killer!
on
