sportsman 600/700 ignition fix?
I was roaming around the old internet today and happen to stumble across something that could maybe end up saving some folks a few hundred bucks, if it works. While I don't know the exact details of what it is that fails on the 02-06 sportsman 600's and 700's ignitions but I'm sure some of you out there do. Could this be a $300 cheaper fix? http://www.ebay.com/itm/Ignition-Upgrade-CDI-Stator-Polaris-Sportsman-700-Carb-2002-2003-2004-2005-2006-/291218764261?hash=item43cdfdb1e5&vxp=mtrHappy Independence Day!
The RM system just uses the charging coil of the original Ducati stator for the ignition source since the charging coil is stronger.Problem is if the charge coil fails you're stuck,have to find another Ducati stator and I have had the charging coils fail before,even before the updated ignition kits were available. To me it's just a cheap bypass of a system that needs to be completely done away with and complete Kokusan kits have been around quite awhile that do this. Buyer beware on this imo..
I was hoping you were going to chime in on this OPT. I kinda figured that was what you were going to say though. Will the Kokusan stators not cross over to this setup? Or is that what the whole kit does and switches everything from ac to dc? Or is it just an all around better built system? It does seem that replacing ALL the components is the safest and only sure-fire way to go. It makes sense that it would work with how they worded it but I still had a sketchy feeling about it. Once I start to have problems with mine I'll just bite the bullet on the whole kit and do it right.
Appears you have the updated ignition already as these models share the same stator as yours.If the stator shows faulty you don't need the kit,just the stator.
Usage : 4010901 Stator
Year Product Model Assembly
2006 ATV SPORTSMAN 700 MAGNETO - A06MH68AA/AD/AF (4999200179920017E01)
2005 ATV SPORTSMAN 700 ENGINE, MAGNETO - A05MH68AK/AN (4999200179920017E01)
2005 ATV SPORTSMAN 700 ENGINE, MAGNETO and RECOIL - A05MH68AD (4999609960E04)
2005 ATV SPORTSMAN MV7 MAGNETO and RECOIL - A05MH68AP (4999609960E04)
2005 MIL SPORTSMAN MV 7 ELECTRICAL, IGNITION - A05MH68MB (4999609960E04)
2004 ATV A04CH59AF SPORTSMAN 600 MAGNETO - A04CH59AF/AH/AJ/AT/AV (4986108610D13)
2004 ATV A04CH59AK SPORTSMAN 600 MAGNETO - A04CH59AK/AL/AN/AQ/AW (4987318731D13)
2004 ATV A04CH68AC SPORTSMAN 700 MAGNETO - A04CH68AC/AF/AH/AJ/AT/AV (4986128612D13)
2004 ATV A04CH68AK SPORTSMAN 700 MAGNETO - A04CH68AK/AL/AN/AO (4987318731D13)
2004 MIL SPORTSMAN 700 MILITARY ELECTRICAL, IGNITION - A04CH68MB (49MVIGNITION04SP700MV)
That is a good question as the stator itself is pretty high. When you think about it yes you would get a new flywheel, cdi,coil and regulator for a couple hundred bucks more in the kit than just replacing the stator. These parts would certainly cost a lot more buying piece by piece.The more I think about it the better it sounds.. I would hope that the old cdi,coil and regulator could come in handy if ever needed also.
WesTech
11
08-11-2015 07:55 AM
