2000 polaris xpedition 425
Old 01-08-2017, 02:43 PM
Xpedition guy's Avatar
Default 2000 polaris xpedition 425
Problems with the speedo. I have already posted that my headlights and tail light are out and my 4x4 doesnt work either does my speedo.... well i put a new battery in now my winch works but nothing else has changed. I have searched high and low for a speedo every where cannot locate one. Does anyone know where i could get a working speedo or a new one?? Does anyone in the u.s. rebuild them. I need help
Old 01-08-2017, 03:00 PM
You can keep a check on ebay on this,but none on there that I've seen.It's NLA everywhere. Plus have you ruled out the wheel speed sensor if registering speed is your problem? If the speedo itself is bad,some have repaired theirs. Not sure how you feel about doing that.KA7OEI's blog: Repair of the speedometer on a Polaris Sportsman 500 4-wheeler Plus on the awd you can jump the brown/white to the brown in the speedo connector and this bypass the ground from going through it. This may allow awd to function. Plus here's one place that may help on speedo repair.http://www.prospeedo.com/index.php/p...cluster-repair
Old 01-08-2017, 03:08 PM
Its has a new wheel speedo sensor... i was hoping someone out there repairs them so i could send it out to be fixed as i dont really want to attempt it myself
Old 01-08-2017, 03:09 PM
I have been looking for a used speedo for thia machine for the past 4 months unable to find one
Old 01-08-2017, 03:25 PM
Then this place seems to be your best bet if you want to keep the oem speedo and not jump to a Trail Tech or something of that nature. Motorcycle Digital Speedometer Repair call Prospeedo 1-800-277-9269
Old 01-28-2017, 12:10 AM
marchant_13's Avatar
Sorry to change the subject a bit but I am new to the forum and I am trying to figure out how to post a thread. I recently broke the gear shift shaft on my 2000 Polaris xpedition and have bought a replacement shaft. I have removed the clutch case and exposed the clutches but I can't figure out how to remove the clutches to remove the broken gear shaft. Any guidance would be greatly appreciated.
Old 01-28-2017, 08:22 AM
Before you go any further get this.https://www.tradebit.com/filedetail....pair-1999-2000 Will save you time,money and hair pulling and possibly damaging other parts. Good instructions on repair and service.
Old 01-28-2017, 10:48 AM
Do you have to pay $8 each time you look at the book or is it just a one time fee?
Old 01-28-2017, 10:51 AM
One time fee.. Just down load it and save it to your document files. Easy to print off pages as you need them if you wish.
Old 01-28-2017, 03:39 PM
Thanks Old Polaris Tech! I got the pdf however I couldn't find the clutch assembly that is like mine...mine looks like this
