01 honda foreman rubicon, electric start doesnt work
Old 04-17-2017, 06:31 PM
Hradek7's Avatar
Default 01 honda foreman rubicon, electric start doesnt work
when I turn the key on the dash lights up, I hit the start buttom and the display disappears, no clicks or anything when I hit the start button, pull starts fine and runs but doesn't know what gear I'm in and the speedo doesn't work either, any help? ran fine when I took it to the woods, got back on and now it started doing all this
Old 04-18-2017, 01:59 AM
A bad connection between ignition circuit and battery, or a bad earth. It is probably going to be between the regulator and ignition fuse, if on the positive side. Could be the ignition switch, have you tried wiggling the key?
Old 04-18-2017, 07:30 PM
Hradek7's Avatar
my battery reads 13.35V, it should be 13.0-13.2, that being said I put a battery charger on the battery still attatched to the quad and it started right up? is my battery bad then? now I'm really confused
Old 04-20-2017, 01:23 PM
Well it is flat, or the connections on top may be bad, clean them, charge it up, if it doesn't then start, get a new one.
Old 04-21-2017, 09:35 AM
Hradek7's Avatar
low amps in battery, got a new battery started right up, thanks
Old 04-23-2017, 02:19 AM
Check that it is charging by putting the voltmeter across the battery when running, if it isn't over 13v and under 14.5v (should move about a bit as you increase revs) something is wrong.
Old 04-23-2017, 06:02 PM
Hradek7's Avatar
now its not shifting, the speedo doesn't work, d1 d2 esp just flashing, any ideas?
Old 04-25-2017, 11:35 PM
LBSammy's Avatar
Sounds like an error code for the electronic shift system. Google the code you're getting. When my Recon did this it was the angle sensor.
dynocompe
11-26-2016 06:32 PM
Johnny821
10-22-2016 09:11 PM
Aggie1127
Technical and How-To Articles
10-14-2016 01:40 PM
Jasonsturgis
09-28-2016 12:06 PM
chinlucd
08-17-2016 10:54 AM
Quick Reply: 01 honda foreman rubicon, electric start doesnt work
