predator 50 leaning out
hi there, new to posting on the forums. this quad is a 05 i believe and i have a question. this thing has new piston and rings, coil, carb etc. running ams oil dominator at 32:1. this thing runs amazing for about 12-15 min. after it gets warm, it starts to lean out and die. all vent tubes are good. it'll run after it's warm choking it. im just stuck at the moment. any suggestions would be greatly apprenticed.
If fuel flow is good check for spark when this happens and also compression even though you have a new top end.Plus the most over looked thing on 2 strokes are crank seals.If you need a cheap manual that can help you trouble shoot problems. 2005 Polaris Predator 50 Service Manual PDF Download
