Cvt problem? Only moves with a push.
I have a Kymco mongoose 90. Long story, but it sat in a warehouse for 8 years. Almost brand new. Replaced the carb and it ran better, but it will only move if I give it full throttle and push it. If I lift the rear end, it runs fine. Does anyone have any experience with this? Any suggestions would be appreciated.
I just took the belt off. It looked good, but I wanted a second opinion, so I took it to the dealer. He thought it looked good. I took carb cleaner to the clutch. What should I look for on the clutches?
They make nests and their wastes cause problems.
With you having the belt off, this isn't your situation.
IMO you'll have to remove both front and rear clutch and inspect.
Front for bad rollers(doubtful) and make sure it slides on the spacer. Rear: squeeze the clutch face. It should slide. If all that is freely working, it's not the clutch.
