03 Kodiak 400 , no spark at the plug,
Old 07-22-2017, 04:33 PM
bobrbo's Avatar
Default 03 Kodiak 400 , no spark at the plug,
checked all connections at the coil, found negative wire loose, tightened bolt/connector, still no fire wandering about ignition module
Old 07-22-2017, 10:36 PM
Mocnyang's Avatar
A situation like this you need to check everything in the ignition system before swapping the cdi. Like the switches, coils, wires, connectors etc. A cdi will be about $300 when it could be as simple as a broken wire that you can fix in 5 min.
Old 07-23-2017, 02:06 AM
Some new CDIs come with a warning, "Ensure negative wire is properly earthed before use" so I guess if the neg is disconnected, it can blow the CDI. It is worth getting a manual so you can check out all wires to the CDI before spending on a new one, but my guess would be the bad wire has cooked your CDI.
Old 08-01-2017, 10:23 PM
Mocnyang's Avatar
Did you get it fixed?
Guzziman53
04-27-2017 11:51 AM
grizz450se
11-05-2008 03:29 PM
klze
01-11-2008 01:41 PM
Quick Reply: 03 Kodiak 400 , no spark at the plug,
