Ring gap
Manual shows piston to cylinder clearance between .00118-.00197 (.03mm - .05mm) on average. .0047 is service limit called for.
Ring end gap just shows max allowable range,but normal gap I've found on Polaris replacement piston and ring end gap between .010-.016 in most cases. Depends on if oem or after market piston and rings are used.
"Piston Ring Installed Gap"
Service Limit:
.030(0.75 mm)
If you need a manual.. Sportsman,Scrambler,Outlaw all the same.2002 Polaris Sportsman 90 Service Manual PDF Download
Service Limit:
.030(0.75 mm)
