2000 Rancher ES Blowes main fuse
New here and can use some help. Neighbor has a 2000 Rancher ES blows main fuse with key off. Problem started when riding, just died, found blown fuse. Rigged up test light to each side of main fuse spades. The only way the light will go out is to disconnect the dash, rectifier and key switch. What do these three things have in common. Or does he have 3 different problems. Limited tools, working at the deer camp.
If the fuse blows with the key off, the fault is in the wires between main fuse and ignition switch. All that is in that circuit is the regulator, so if the regulator is OK, a red wire from main fuse to regulator or to ignition switch has shorted out, or the switch has shorted internally. Unplug the switch and check if the fault is still on. If it is, check those two red wires all the way from main fuse to regulator to switch. As it is a short to earth, it is less likely to be inside the loom, so check where the red is visible first.
