my 2000 polaris 500ho wiln not go into 4x4.
Old 10-16-2017, 04:22 PM
harleybikerdude's Avatar
Default my 2000 polaris 500ho wiln not go into 4x4.
The AWD light comes on but, the drive shaft from transmission will not turn. Grinding type sound in transmission. very quiet though. Speedo does work. Any ideas?
Old 10-16-2017, 04:34 PM
I'd jack the atv up,roll the rear tires and see if the prop shaft splines may have stripped on the transmission output shaft. This was one common thing that happened if the zerk wasn't greased regularly.Item#5 on the parts break down. Hopefully it's just that and not an internal transmission problem.
Attached Thumbnails my 2000 polaris 500ho wiln not go into 4x4.-a3d903121c393361d0cdaef12c9eaa43e232fdda.png
Old 10-16-2017, 04:53 PM
The Splines /in the shaft are fine. The output shaft from the transmission will not turn. Internal? How hard to fix? Thanks for the fast response!
Old 10-16-2017, 07:03 PM
This is something you'd really need a service manual to help in tear down and repair.2000 Polaris Sportsman 500 RSE Service Manual PDF Download
cswiger
10-02-2017 04:30 PM
martyg
Polaris Side by Sides
08-11-2017 08:21 AM
Adam Roby
08-07-2017 09:33 PM
Grn.Mtn.Boy
08-05-2017 07:26 PM
infamousdave
07-27-2017 11:31 PM
Quick Reply: my 2000 polaris 500ho wiln not go into 4x4.
