idling fast
Old 10-18-2017, 12:04 PM
Michael Claggett's Avatar
Default idling fast
1995 Honda fourtrax 300 2x4 The carb. has been rebuilt, and now it idles fast but the adjustment screw is all the way out. ???
Old 10-19-2017, 03:50 AM
Check the cable adjuster on the handlebar lever box. If the cable is tight, the lever on the carb doesn't touch the adjuster on the carb. Other possibilities are butterfly sticking or an air leak, or choke slightly open.
Old 10-19-2017, 01:21 PM
thanks I will try that
Old 10-19-2017, 02:33 PM
DirtDevil101's Avatar
Couple thoughts:
1) make sure the slide/needle jet is installed correctly and verify visually or by feel that your slide almost bottoms out with no throttle
2) make sure your intake boot is installed correctly & has no cracks - excess air can raise the idle...
Old 10-20-2017, 03:18 AM
"1) make sure the slide/needle jet is installed correctly and verify visually or by feel that your slide almost bottoms out with no throttle"
Honda 300s have a butterfly throttle CD carb.
Old 10-20-2017, 07:49 AM
Oh...well that makes it easier then...
But surprising at the same time...
Ajax
03-17-2020 09:28 AM
clayh
10-09-2016 01:13 PM
230e
09-23-2016 01:03 PM
COFatboy
08-21-2016 06:04 PM
Quick Reply: idling fast
