Sportsman 500 front shock replacement
Old 12-12-2017, 09:41 PM
I.b01's Avatar
Default Sportsman 500 front shock replacement
I purchased a 1998 SP500 this spring and mounted a cycle country manual lift plow for the first time after painting it and trail riding the atv this summer. I noticed the front end dropped quite a lot with the plow up and decided to make some spring spacers from 2" PVC.
When I had the coil spring off on the front, the shock piston does not extend out on its own, I can push it down or pull it up with some resistance. Is this correct or will it cause any issues?
I have it all put back together for now and the plow now only sags about 1/2" instead of the 2"+ it was.
Is it normal for these shocks to not have pressure?
Also, if the the cartridges must be replaced, does there happen to be a parts store number that will interchange?
Thanks!
Isaiah
Old 12-13-2017, 03:32 AM
Shock is worn out if the shaft wont rise on its own. Several different brands such as Bronco,Kimpex and other no name cartridges out there. Just use google. https://www.ebay.com/itm/Polaris-Spo...VZ-K9z&vxp=mtr
slowgsxr97
09-08-2015 04:37 AM
rgervais
08-03-2012 05:05 PM
jjlash
12-07-2006 10:42 PM
NotuRaptor2
06-02-2003 08:35 PM
Quick Reply: Sportsman 500 front shock replacement
