use different oil than PS -4 FULL SYNTHETIC
You can use just about any auto/cycle oil since most atvs have cvt clutches. Just make sure it's fully synthetic.Mobil 1 0w40 is one of the most common oils used along with the newer 5w50,plus Amsoil is another one.The list is really endless and many people use Rotella T6 that can be used in cvt engines along with wet clutch engines in cycles,etc since it's jaso rated.Choice is up to you as far as oil brands..
You might want to do some research on those Fram oil filters. My company did some work for and oil filter distributor, comparing various brands of oil filters and their construction. In the end Fram filters were almost last and the information made headlines. Many of the cheap no name filters were constructed better than the Fram filters. I was a Fram guy for many years but know that I have first hand knowledge of their construction I will never touch one again.
The quality is second to none, and unlike others they are 100% USA made.
Check out Fram Ultra on sites like Bitog, you will get an eye opener. In fact, Honda uses Fram as their OEM filter supplier.
I guess I better not say anything to my truck with over 276,000 miles that's been using them for 18 years.. People have trash talked Fram for years and yes I've seen the cutaway comparisons on the different brands along with cheapest Fram filters,but spend a couple bucks more for the ToughGard and it's as good imo as Wix,Bosch,K&N or any other filter out there. Again just mine and my trucks opinion..
