Antifreeze
Old 02-21-2018, 07:24 AM
RticKwad's Avatar
Runs Stealth!
Default Antifreeze
Hello,
Its been awhile. I was just curious what is recommended for radiator fluid? Can I use any non-Polaris brands?
Thanks,
R'
Old 02-21-2018, 07:46 AM
Any good brand 60/40 or 50/50.
Old 02-21-2018, 11:28 AM
RticKwad's Avatar
Runs Stealth!
Okay thanks OPT. No concern adding to whats there or do I need to drain old first? I assume I add at the top not the white reservoir on the bottom left. I read some confusing text about air bubbles leaving the top off, start it until bottom reservoir fills , add more between fill lines then finally cap it?
Seems dangerous, leary about not caping the top after fill. Dont want antifreeze exploding up in my face or eyes, lol..lol...maybe Im too cautious?
Thx,
R'
Old 02-21-2018, 12:54 PM
Just drain the radiator by opening the valve,plus pull the bottom radiator hose leading to the water pump.You can flush the system with water by hooking the bottom hose back up,fill the radiator with water crank it up and leave a hose running slowly in the radiator while the drain is open.Let it flow out for a few minutes and remove the lower hose again to flush the water out. Tighten drain valve,replace the hose and fill the radiator with coolant. Have the front wheels off the ground a little to aid in removing trapped air. Run the engine(cap off) until the fan cycles on. Radiator level should drop. Top off radiator and let the fan cycle a couple times.This should be enough in most cases to remove any air pockets. Top off radiator,replace the cap and fill the over flow bottle to the full mark. Test ride to make sure the fan kicks on and off and no hot light.
Old 02-21-2018, 10:09 PM
user493's Avatar
Moto Psycho
If the fluid is still good and there's no crud in the radiator you can just top it off.
Old 02-22-2018, 09:02 PM
RticKwad's Avatar
Runs Stealth!
Good info, let ya know how it goes guys!
R'
Old 02-23-2018, 04:51 PM
RticKwad's Avatar
Runs Stealth!
Any words of wisdom on how to pop off the red cap on the white coolant reservoir without breaking it? Lol
This maintenance is drivibg me CRAZY!!!
Old 02-23-2018, 05:02 PM
Unscrews.. If it's tight use some channel locks.
Old 02-23-2018, 11:21 PM
user493's Avatar
Moto Psycho
Lefty loosey?
Old 02-24-2018, 02:43 AM
Lefty loosey?
Righty tighty..
Quick Reply: Antifreeze
