Carb help
Old 03-18-2018, 04:20 PM
neo27ny's Avatar
Default Carb help
i have what I think is a TM36 carb from what I can find. I'm looking for an idle screw but I'm getting a lot of different types. Anyone know which one I need?
Old 03-18-2018, 04:31 PM
Here's a couple different ones. Both show #49 for the spring #50 for the idle adjuster if this is your style carb.https://www.jetsrus.com/carburetor/c...iew_parts.html Mikuni TM36-68 Exploded View - Replacement Parts Listing
Old 03-18-2018, 06:46 PM
neo27ny's Avatar
That's not the exact one but I don't know carbs well enough to tell what parts are interchangeable. I tried an idle screw off of a vm22 round slide and the threads were bigger than the hole. Let me see if I can get a picture on here.
Old 03-18-2018, 07:51 PM
Several different versions on the TM36(if that is what you have) and like you found out other carb parts won't work. You might try this image search to see if you can trace it down.https://www.google.com/search?q=tm36...h=744&dpr=1.25
Old 03-19-2018, 08:59 PM
neo27ny's Avatar
I'm pretty sure I have a TM36-2. It came in top and sidle idle screw adjusters. I need the side idle screw. I did find out though supposedly this is a four stroke carb. I've had it for awhile laying around, so I was going to use it on my trailblazer 250 when I do my build...
Old 03-21-2018, 06:04 PM
Find a cheap Mikuni VM30 carb on ebay.
Bartman
06-22-2003 06:33 PM
Shadow11m
06-17-2003 07:21 PM
kmoore007
05-08-2002 01:33 PM
thomascw
04-12-2001 10:12 AM
Quick Reply: Carb help
