2005 Eton Viper 90 RXL-90R Broken Swingarm HELP
My son rides a 2005 Eton Viper RXL-90R the swingarm broke in two. Not sure why or how as my 8yr old doesn't ride it hard, coulod have been previous owner damage. I welded it back together the best I could and unfortunately it's tweaked pretty bad, it doesn't track straight but it rides ok.
The swingarm part # from Eton 811053 is listed as no longer available. Checked Ebay and no luck there either. I couldn't find a lot of info on alternates besides one "universal" swingarm that is 4" extended which requires a longer chain. Not sure how this attaches to the rear axles as it's totally different than stock. Also noticed the Polaris Predator 90 uses a similar swingarm, is this a possibility to make work with the Eton? Looks very similar but again I'm not sure on all this and can't any info online.
Any insight would be appreciated.
Thanks
Thanks
Look up newer models most of the time they are the same part or close enough they will work.. I just did a quick search and their was a complete setup on ebay. you could also find a buddy that can weld/fab well and have him replace the broken tubes. Also you can look at other atvs of that size. they are all pretty close to the same.. I just tossed out that exact part 2 days ago
hustlin2makeamillion
04-12-2011 07:29 AM
02-10-2011 07:01 PM
