1999 Yamaha Warrior Carburetor Issue
Old 07-20-2018, 07:41 PM
WillGrav93's Avatar
Default 1999 Yamaha Warrior Carburetor Issue
I have a 1999 Yamaha Warrior and I just replaced the carburetor with a brand new one and I also replaced the intake boot. It was running before the new carb. and intake boot but was running a little rough and the previous carb. was missing the cover so I just figured it would be better to replace the whole carb. with a new one. I've adjusted the fuel mixer screw and the idle screw. It won't start and idle but I can use the throttle to keep it running. Any ideas?
Old 07-21-2018, 03:18 AM
Clean the jets out, yes it is new, but could have dirt or metal shavings left in from manufacture. Set the mixture screw about 2 turns out, and see if you can get it to idle then.
rider001
08-24-2017 11:11 AM
tabaka45
06-06-2017 11:47 AM
rwithey3
07-07-2008 02:25 AM
King Lu
06-05-2007 10:07 PM
greateng
10-02-2006 11:56 PM
Quick Reply: 1999 Yamaha Warrior Carburetor Issue
