would gear position sensor keep 05 recon from starting?
Old 08-20-2018, 11:22 AM
camoguy's Avatar
Default would gear position sensor keep 05 recon from starting?
would this sensor keep 2005 Honda recon from starting? it will turn over but no spark
Old 08-21-2018, 01:43 AM
No, the Recon is just about the only Honda Quad to still use pure AC ignition, an exciter coil in the alternator provides the power, a trigger coil outside the flywheel provides the timing and the CDI converts this into a power pulse to the coil.
One proviso, Hondas have a sort of boost system which increases spark when in neutral, so if the CDI doesn't get the signal to say it is in neutral, it won't boost the spark, and often you can't see any spark at all when you spin the engine on the electric starter, strangely, you still get a decent spark using the pull start though.
pinetag
12-04-2008 05:39 PM
pinetag
Utility ATVs
04-27-2008 08:35 PM
Opteron
01-11-2006 10:18 PM
jeremys
01-01-2005 10:26 PM
Quick Reply: would gear position sensor keep 05 recon from starting?
