Eiger 400 rear differential fluid change
Old 09-18-2018, 06:41 AM
Eiger1919's Avatar
Default Eiger 400 rear differential fluid change
I'm trying to change the rear differential fluid in the Suzuki I can't get the top bolt out to put the oil in. Do you turn the bolt towards you or away from you. I'm turning it away from me and I still can't get it loose. I have tried fluid film and still can't get it off.plzzz help!!!
Old 09-18-2018, 08:32 AM
Dazeys's Avatar
Can't wait to feel that 130 HP at the dunes.
Counter clockwise to loosen.
Old 09-18-2018, 09:06 AM
Eiger1919's Avatar
I have been turning it that way wasn't sure if it was the right way or not though I can't get it off it doesn't look rusted it all but I don't think it's been off in 2 years I don't know if I should try heating it up with a torch or try some penetrating oil. I was also thinking of trying to go at it with an impact gun if I could get in there but I don't know if that would be a good idea or not
Old 09-19-2018, 02:16 AM
A good fitting hexagonal socket and long tommy bar is best. You can warm the case round it, but don't overdo it. You could try an impact screwdriver, but it is all to easy to round off a tight bolt head with an impact gun.
Old 10-07-2018, 08:39 PM
OutdoorExplorer's Avatar
A 6 point socket is best of you have it. As mentioned, turn counter clockwise. It shouldn't be too tight. A 1/2 inch drive socket with a breaker bar should loosen it. I would avoid the impact.
mad-atver
04-25-2013 03:26 PM
s16
01-29-2013 05:40 PM
mrsnooka
09-23-2002 06:40 PM
Quick Reply: Eiger 400 rear differential fluid change
