compression
Thanks for that. I didn't know if the 400 H.O. had that too. Other than displacement is it basically the same engine as the 500 H.O.? They had one engine that I think was the same as the 500 except for the bore, but I can't keep track of them all.
With all this being said, a cylinder leakage test is the best way to check a 4 stroke. It tells you a lot more info. Problem with that is a lot of people dont own a compression gauge let alone a cylinder leakage tester but it is the better test.
adapter to pressurize the cylinder with compressor air and listen for leaks at the intake, exhaust, and crankcase. Of
course the cyl has to be at TDC on the compression stroke, and constrained from moving. I don't know if the Polaris
auto-DV holds the Exh valve open when engine is NOT turning.
I have 4 compression gauges, and they all give different readings.
Related to this auto-decompression feature on newer quads: most, if not all, of the current crop of small Honda
and Honda-clone OHV small engines have this feature. As the valve lash goes out-of-spec, the DV stops working,
and they get super-hard to pull-start. Moral: check and set valve clearances!
If one does not want to buy one, he/she can make an
94HARLEY: you can use any pressure from the air compressor that you want, tho leaky rings or valves will be more
apparent with higher pressure, say at least 20psi. If you hold the engine at TDC, the torque on the crankshaft is minimal.
I do not use my leak-down test rig for single cylinder engines. It is made by Moroso, and I think it calls for 100psi from the
compressor, IIRC. I have used it mostly with 4-valve V-8s where cam overlap was significant. That meant that you could get decent
compression #s with a compression tester, and still fail the leak-down test.
I realize that many ATVs have centrifugal clutches and it may be difficult to keep the engine from turning. This is when you
want a manual trans and someone to hold the brakes.
duckterrier
Technical and How-To Articles
04-25-2012 07:05 PM
