02 sportsman bogs at half throttle
What is the easiest way to tell if you have a worn cam on 2002 Sportsman 700? It runs fine up to mid rpm range then bogs and if I hold my hand in front of carb without air cleaner I get some gas blowing out of the carb when it bogs. Running it with the air filter housing on makes no difference. Inspected the carb diaphragm and look fine. Slide in carb lifts up as you accelerate so I assume the diaphragm is good. Been thru carb, new fuel pump, new plugs, new fuel filter, new intake manifold and compression is 150 psi on each cylinder. Would a weak valve spring cause this?
A weak valve spring would cause valve float and more than likely make contact with the piston.
Do you think the cdi module could cause this? I connected a timing light and ran the atv with it connected and the light never quit flashing or interrupted when the atv bogged. The spring on top of the carb diaphragm did for some reason come dislodged and was sitting sideways under the cover. I took the carb off and dissasembled it to clean it and found that problem. I reinstalled it correctly and it has been find since then.
The problem with the spring being unseated occurred BEFORE all of my problems started with it bogging down. It still has the problem. The carb was just the first thing I checked, that is when I discovered the spring being unseated. I cleaned the carb and reassembled it but still have the problem
According to the parts diagram your machine should have a 155 from the factory. According to the technical manual it came with a 162.5. If it were me(and what is going on that I think may be going on) Id stick a 150 in it and see how it runs after that(with air box and snorkel) One other thing we saw at our elevation(4200) the jetting charts were a bit on the rich side. If the book showed to use a 150 or so, we actually stuck 147.5 in a they ran great.
Yes I did run it with the air box on it and not much difference. The original plugs looked fine, maybe a tad lean if anything. We are at 742 ft elevation here. What do you think could have caused the spring above the diaphragm to get lodged sideways? There is a nipple on the cover that the spring goes over to keep it centered. I am going to pull carb off and go through it again. Anything special I should look for or pay attention to. Thanks the jet has never been changes so it has original in it now
Did this start all of a sudden, or did it slowly get worse and worse?
