2006 Bruin 250 2wd. YFMBV
Old 10-23-2018, 04:50 AM
Goose1963's Avatar
Default 2006 Bruin 250 2wd. YFMBV
So a quick little history on this. This ATV was given to me as a jigsaw puzzle in the engine department. I now have it reassembled and went to start and found I needed to readjust valve clearance. That complete I attempted again and no start. When I unplugged the spark plug the boot came off and no copper wire coming through the casing. Got new coil and am getting no spark. Does anybody have any troubleshooting ideas or help for the ignition system?
Thank you in afvance for any help.
Old 11-05-2018, 11:07 AM
Timbo2500's Avatar
Have you tried checking the resistance on the stator? I have the specs if you need them.
Old 11-05-2018, 02:52 PM
Goose1963's Avatar
Default Stator
i have not. If you can that would be awesome. Thank you. On a side note I noticed that when cranking it seemed as tho the starter clutch would slip (not turn the engine over) but the pull rope would pull it over fine. I am putting a new clutch in for the flywheel
Old 11-09-2018, 12:19 PM
Timbo2500's Avatar
Message me your email address and I will send you a copy of the specs. There are graphics that outline the wires to check which will be much easier than me just providing the resistance ranges.
ohiobass
12-19-2009 08:52 AM
Chumly75
04-24-2008 06:40 PM
Stump
08-19-1999 01:21 AM
Quick Reply: 2006 Bruin 250 2wd. YFMBV
