1998 Honda recon slight bog problem
Old 11-14-2018, 10:12 PM
Cody Philpot's Avatar
Wildreconrider
Default 1998 Honda recon slight bog problem
I have a 1998 Honda recon foot shift and when you snap the throttle real quick, it has a slight hesitation and if you snap it and hold it, most of the time, it will die, other times it will rev up after the bog, baffles are wore out in the exhaust
stock jettin
no carb mods
no motor mods
no air box mods
all stock
looking for some insight, thought maybe rejetting but don’t know what size to go with, lmk what you all think.
Old 11-15-2018, 02:08 AM
Fit a new plug. Could be wear in the carb, or just dirt. I would give it a clean and see if that fixes it. If not, new standard jets or a new carb may. However I did once have this problem on a 300, and fitting a used carb off another bike didn't fix it. In desperation I fitted a new CDI, instant cure, bike ran fine afterwards.
Old 11-15-2018, 05:44 PM
Wildreconrider
Default 98 recon bog
I’ll clean the carb
put a new air filter on it not long ago, may just check that just in case, I thought if nothing fixes it, I work at a Honda shop anyways, get like 2-3 diff size jets and try to play with the carb a little see if that helps
Wildreconrider
Also will put a new plug in it
doober
06-04-2003 01:27 PM
4wheelr220
04-03-2003 09:15 AM
UrbanCowboy
12-24-2001 07:47 PM
cowboy
06-14-2001 06:44 PM
Quick Reply: 1998 Honda recon slight bog problem
