2003 Polaris Sportsman 700 loose front cv axle
Old 12-10-2018, 12:10 PM
micahhoward's Avatar
Default 2003 Polaris Sportsman 700 loose front cv axle
Hello,
I am going to link a video to an ATV I'm working on. Before I dug in to it, I thought it was the u joints. When I hold the end going into the differential, the u joint is tight and has no play. This machine has 5,500 miles. Is this normal? is it something that should be fixed? If so, how? a new differential?
Thanks for any help
Old 12-10-2018, 02:14 PM
stendori's Avatar
I'm watching you!
seems like excessive play meaning bearing in case is bad??
Old 12-11-2018, 04:43 PM
Should I look into replacing a bearing or would the whole differential need to be replaced? I just want to weigh the options.
If I let this go on without servicing it, how long before something major breaks because of it?
srievley
04-04-2018 11:27 PM
Doug Labat
06-17-2017 05:08 AM
R00ST
02-17-2004 10:31 AM
Quick Reply: 2003 Polaris Sportsman 700 loose front cv axle
