softening up shocks on my 2017 570 rzr
Old 02-19-2019, 03:21 PM
pogo ski's Avatar
Default softening up shocks on my 2017 570 rzr
can you shorten your springs to spften up your ride
Old 02-20-2019, 10:22 AM
There are adjustments on the shocks where the springs are. Usually, Polaris has a spanner wrench as part of the tool kit that comes with the ATV/UTV. The pre-load adjustment has a ring that has notches in it. The notches are made for the spanner wrench to fit its two teeth into. The more pre-load on the spring the stiffer the ride and higher the ride height. This is probably how your shocks look:
One thing you want to do when adjusting the pre-load is to jack up that end of your RZR when you adjust so it's easier. Sometimes a little WD-4- between the shock body, and notched sleeve helps too.
pogo ski
Polaris Side by Sides
04-08-2018 01:51 PM
pogo ski
04-08-2018 08:34 AM
pogo ski
04-07-2018 03:01 PM
pogo ski
04-07-2018 08:40 AM
pogo ski
04-06-2018 10:42 PM
Quick Reply: softening up shocks on my 2017 570 rzr
