Lt80 won't start
Lt80 won't start
Pulling my hair out
We bought an LT80 in the fall that wouldn't start. After screwing with it a while it would run for about 10 mins with low power and would die. Compression was around 75 so I put a chinese pison and sleeve in it. Ran like a champ for 2 tanks of fuel but didn't idle very well each time we used it (in the snow). Last time it ran I ran out of gas in the yard. topped it up and it hasn't ran since. Took the carb off a couple weeks ago and the isolator was broken in about 6 pieces. New isolator and gasket are on. Pulled the reed and it has the stainless one still in it. tried the Boyssens and they didn't close properly, nor would it start. put the stainless one back on and i see no air around the valve. Cleaned bottom of carb today and idle jet looked clogged. Buttoned back up and still no luck.
Bike will sputter with starter fluid into the carb, or after pulling a few times with 2 fingers over the carb then held WOT. Fuel is pre-mixed 32:1 and oil tank is blocked off. spark plug has 4 hours on it. Current Compression is 110.
spark is good and it is getting fuel from the petcock to the carb and bowl is full when I open the drain screw.
Thoughts?
Thoughts?
I shoved this thing aside from frustration for a month and started playing with it again today. I just pulled all the jets out again and made sure they were all clear and made sure everything was cleaned up. Pipe is currently off the bike. Still no luck besides starter fluid into the carb.
I have tried 2 different carbs, I am at a total loss unless it is reeds.
Have you checked compression again? Those Chinese kits don't have the ports chamfered I believe, so you have to do it before assembly, if a ring caught on a sharp edged port it could do damage. Did you fit the rings the right way up. I didn't know they had a right way and couldn't weigh up why the rings didn't fit, Jack, on here, put me right.
