04 kawasaki prairie700 cooling fan not working
Radiator fan not running. Overheating. I get no power to the fan. Checked fuses under seat. They are all good. Checked wire going to the fan fuse and no power there. I had key turned on when checking. I have power to the other fuses in the same fuse box. I changed thermostat and thermosat sensor. I also get no power at the radiator sensor wire terminals.. Coolant pump is working as i have good flow through radiator. I am stumped. Any ideas will be appreciated...
There should be a feed, live with ignition on, to that fan fuse, you could jump from an accessory fuse wire to that, and everything would work, but it is better to find where that ignition switch to fuse box wire has broken as it could indicate other wires being chaffed. I would get the wiring diagram and trace it if possible.
