Unkown Kudaki 250 problem.
Hi, first off i need to say i know very little about engines but hopefully i can explain the problem.
My atv randomly stopped starting with the electric starter and i could only bump start it and some time later it wouldnt even start like that.
Started Googeling and most common problems was sparkplugs so i changed both and i also changed the ignition coils and spark plug caps since they fell apart once i took them off.
Now it starts again but still only if i bump start it and electic starter will only work once the bike is really hot.
The carb have always been leaking a little but from what i saw it was just the float or float needle, borrowed another carb from a friend to check if that was the problem it still wouldnt start.
It idles horrible and started to sound almost like a chainsaw.
I got it for very cheap so it's not the end of the world if it's something major broken.
from what i can tell its a 253fmm engine.
Took 2 videos with my phone, recording sound is not good but its the best i could do, maybe someone can hear something.
https://streamable.com/6dls3
https://streamable.com/imtfk
