RPM for a Banshee
RPM for a Banshee
The best I can explain is that the expansion chamber is designed for the stock exhaust duration. When you go modifying the exhaust port you change when the pressure wave reflects back to the cylinder. If the timing isn't right then power is no good. I ported a set of jugs to my standard all around port that had a set of T-6's on it. The power was great until about 3/4 up the rpm scale then it went flat. It wouldnt rev out good. We did nothing but put a set of T-5's on it and then it really woke up. Power down low was the same but screamed on top end. If you notice every set of T-5's that go on e-bay sell for a great price because people know they work.
#15
07-07-2015 11:00 PM
