LT250 rear wheel/gearing question
You don't have to change the rear sprocket. You're quad qill be lower geared with the smaller tires. If you don't like the gearing after you change the tires just go with a 2 tooth smaller rear sprocket and you should be right around where you were with the 20inch tires.
SixSpeed5
8
08-02-2015 05:38 PM
