Suzuki LT80 Light instalation
I am restiling and rebuilding my 1992 Suzuki LT80, and apeared me a problem, witch is instaling a light in front of my brothers machine.How can I get energy to the light??
I'm I forced to get it from the batterie, or can I get it from the motor energy?
Please help me, with some pictures if its possible...
Maier plastics makes a cool new nose piece for the LT80 with a light built in, all switches,wiring and instructions are included. Cost is about 60 dollars, and looks factory when you're done. When my son had an LT80, I put a small 35 watt light on the handlebar, wired it to the ignition switch with an inline fuse (3 amp) so it could only be turned on if the key was on. Use a small,low wattage light,or using it a lot will drain your battery even while running,the stock stator has just enough to charge the battery. You could get an aftermarket stator or rewind yours to run a bigger light. It all depends on how much you want to spend.
07-15-2015 02:07 AM
