Lt 230 cam timing
1986 lt 230 does anyone know whats the specs for the cam?i think its in the manual if you have a manual just check it for me please. i did a top end job and i dont kno how to set the cam?.any advice would be helpful thanx
Lt 230 cam timing
align mark on rotor with mark on crankcase (inside top lip crankcase) keeping timming chain pulled upward...
engage chain on cam sprocket with locating pin at just past top position... align the 2 marks on the end of the cam shaft so that they are parallel with the surface of the cylinder head... fit lock washer to cover locating pin... valve clearance specs... in. .001 - .003 ex. .003 - .005 I hope this is what you wanted? |
Lt 230 cam timing
thanks alot
Lt 230 cam timing
could u give me directions a lil more detail im just starting out fixing my atv. thanx
Lt 230 cam timing
What kind of directions would you like? The info I gave you is straight from the book!
Lt 230 cam timing
for the cam i still dont understand how to do it.thanx alot
Lt 230 cam timing
Are you taking it out or putting it back together?
Lt 230 cam timing
puting it back together
Lt 230 cam timing
Which part?
Lt 230 cam timing
puting the cam back in the head
